OK so I pretty much wired everything up on the OBD1 S52 today. I have a couple questions before I bolt the manifold down.
The FPR vacumn line is just a straight shot with nothing in between going to the bottom of the manifold vacuum nipple?
The 2 large red starter wires on the drivers side harness can both be mounted to the large post on the starter? E36 1 goes to starter and one to fusebox, using E30 distribution block I can just feed these both to the starter as they are just a split off the original main power?
The small nipple on the TB goes to the charcoal canister small nipple but runs the evap emmisions valve in line correct?
I think thats it, so far so good.
