oil dipstick tube bracket mod?
  • graphikg
    • Jan 2008
    • 1614
    My s50 swap has a loose oil dpstick tube. The swap doesnt have a place to brace the tube. What did you all do?
  • e30s50dan
    • Nov 2008
    • 2076
    you can make a small bracket about an inch-half long and bolt it to the intake bracket that runs beside it...pretty easy mod
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
    • MattM
      • Apr 2009
      • 931
      i made spacers for the bolts between the mount arm, and the block out of metal pipe, cut to the right length and painted. works great
      Full Build Thread Here
      • evil_twin
        • Nov 2007
        • 2965
        what dip stick are you guys using to have a half inch bracket made for it to fit?
        M52 dip stick?
        Paypal: vdang5@gmail.com
        Delta Auto Care
        2875-C Towerview Road
        Herndon, VA
        703.435.1375
        My Feedback Thread: Evil_Twin
        • FredK
          • 14761
          I used the M50 525i dipstick
          • whiltebeitel
            • Apr 2007
            • 2098
            M50 manifold and S52 dipstick cause this.
            '89 325i track sloot
            '01 530i daily
            -Enginerd
            • flyboyx
              • 8371
              my dipstick tube came from a 725i (kinda rare, i know) it actually had a v/u shaped bracket on it that mounts to two holes in the side of the block and a bolted clamp that wraps around the tube. it is very secure. i was thinking that the 525i had that bracket too. why don't you have a look at real oem? i would bet it is less than 10 bucks.
              Gigitty Gigitty!!!!
              • erik325i
                • Jan 2005
                • 3567
                It's been a while since I looked at doing this, but if I recall correctly the 525i bracket won't work for some reason. I think it might be because of the e36 motor mount arm. I bought that bracket a long time ago. Maybe I'll take a look at it again to see what it would take to make it fit.
                Erik
                • MattM
                  • Apr 2009
                  • 931
                  i used the 525i bracket, hence my mod
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    me 2!
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1997 M3 sedan
                    2001 325CI DD
                    • shiboujin
                      • Feb 2006
                      • 2791
                      I used JB weld to jb weld my dipstick tube in... lol
                      • evil_twin
                        • Nov 2007
                        • 2965
                        Leave it to you to do something like that Yoshi... lol
                        I made a bracket today, roughly 6" long out of aluminum. Shaped it into an L and drilled 2 holes. Made it right my 1st try WOOT! Now it doesn't move when I pull on it and its sturdy :)
                        Delta Auto Care
                        Herndon, VA
                        703.435.1375
                        • shiboujin
                          • Feb 2006
                          • 2791
                          says the kid with a welded diff.
                          • richardb
                            • 2121
                            2 fat zip ties around the altenator vent tube
                            Transaction Feedback!
                            • jrdeamicis
                              • Nov 2008
                              • 956
                              525i bracket worked just great.
                              Past Car : E30 S50 6 Speed 5 Lug 3.73
                              Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                              ___________________________________________
                              BNB Designs
                              Engine Swaps, Fabrication, Innovation, General Repair
                              Richmond CA
                              Julian 848-248-8029
