My M50B25TU DD build
  • 5KWattson
    • Apr 2009
    • 809
    so after my 2.7 stroker died i really wasnt sure what to do or put back in my 30, until i found a guy with a 93 m50 out of a automatic 325is online hit him up got a smokin deal on the engine harness an ecu, with alot of other misc shit to go along, got it to my shop on the engine stand pulled the pan valve cover and confirmed, what the guy said about only havin 44k on the motor was true that thing is sooo clean and tight still i couldnt believe it, so after that i pulled the ecu cover off to check if the factory chip was still there...kinda wished it was but found a RD chip in it so not too sad about it. so to get back to the swap, im using my 260 stock trans, with my lightened m20 flywheel and 6 puck ceramic disk, i just bought a e34 oil pan w/gasket pick up tube dipstick an tube, i need to source out a booster still along with a throttle cable an mounts, i seperated the auto section of the harness tonight very carefully, i cleaned an painted the valve cover, i am goin to order the front an rear main seals(as percaution) along with the valve cover gasket, spark plugs, fuel filter, a can of sea foam, and the two lil plugs for the engine covers(to keep it looking clean for final install) im sure there is more im just forgetting right now. well ill post some pics soon but lmk what you think so far
    "God created turbo lag to give V8's a chance" Taylor D.
  • 5KWattson
    • Apr 2009
    • 809
    Note: forgot to add this, P/S is gone lack of operation so i pulled it off, No A/C components except the evaporator in the hvac unit, thinkin about gettin a 95 M rack next paycheck as well....i think thats it for now
    • e30s50dan
      • Nov 2008
      • 2076
      Good luck with swap.
      NASA
      BMWCCA member
      PCA member 25yrs
      1991 318IS slick top
      1997 M3 sedan
      2001 325CI DD
      “whoever turns the wheel the least, wins"
      • 5KWattson
        • Apr 2009
        • 809
        thanks bro, hey i was wantin to ask someone with this swap done, how F-ed off is traction with say that 4:10 lsd i have out back and stock wheels, like in the rain will i even be able to move lol
        • e30s50dan
          • Nov 2008
          • 2076
          I am running a 4.10 LSD with G240
          NASA
          BMWCCA member
          PCA member 25yrs
          1997 M3 sedan
          2001 325CI DD
          • SamE30e
            • Sep 2007
            • 4319
            Samesies. I put it off the limiter in 5th last night against a GSR civic hatch. I pulled like 8 lengths on him from 100 to 230km/h
            1985 325e 2.8 Turbo VEMS
            • 2002maniac
              • 4260
              My brothers modded M50 (cams, chip, exhaust) runs the 4:10 with the Getrag 260 and it's just fine around town. Traction isn't an issue, the only downside is cruising on the freeway.
              • richardb
                • 2121
                Same here, 4.10 LSD small case w/ G240. It comes out sideways in the rain easy, it can be dangerous. Cruising the highway SUCKS. I'm looking to swap out for a 3.23 or something soon
                Transaction Feedback!
                • 5KWattson
                  • Apr 2009
                  • 809
                  whats the diff between the 240 and the 260?
                  • 2002maniac
                    • 4260
                    240 is smaller/weaker and has slightly different gearing. It is the stockl tranny for the '91 318i and 318is
                    260 is stock for the 325e and 325i
                    • zav3n
                      Curious George!
                      • Mar 2007
                      • 223
                      240 ftw
                      • g22
                        • 274
                        I've got the g260 with a 3.91 diff and an M50. No traction problems. I've really noticed no difference at all with the revs. Same as with the M20.
                        • 5KWattson
                          • Apr 2009
                          • 809
                          oil pan got here yesterday with the dip stick, tube, pickup tube, new pan gasket, and oil level sender, the pan is super clean only 3 fins are slightly damaged and the pan is spotless otherwise, along with that my 320i brake booster came in as well(remaned) so ill pick it up tomorrow morning along with the pickup tube gasket and hopefully ill have the motor in and bolted the the trans tomorrow
                          • SamE30e
                            • Sep 2007
                            • 4319
                            Just go with the G240. Honestly, they need to be in the S52 power range to actually start breaking things, and even then they need to take a beating like a russian hooker to actually do it. It makes the swap essentially bolt in without needing a new tranny crossmember.
                            • 5KWattson
                              • Apr 2009
                              • 809
                              if i was in the market for one i prob would but my 30 came with a 260 so im just guna leave it as is, but the cross-member from a 260 doesnt it just have to be cut and re-welded or cant you shim them trans mounts...from my understanding with the twist from the m50 i can just do that right?
