Hey guys/gals;
I have a problem with my e30. I finally hooked up my heater core after it had been a year of driving it with no heat. The problem was that the heater valve was leaking. So I replaced the heater valve, and hooked up the coolant hoses again. I have 1 hose coming from the block, and the other hose going to the T. My problem is when I'm at an idle, the heat is fine, but when I drive and rev the car over 2.5-3k I loose all heat. Anybody know the problem? I'm thinking that I have the hoses on wrong, but it shouldn't make a difference really.
**Switch the lines and the problem should be fixed
