Pin # 28 on Red label 413 DME
  • kevmo707
    • 62
    My car has been driving perfectly for a few months now and a couple of days ago it died coming into my drive way. I thought it was the fuel pump relay or the pump itself, but its not. I took the dme out and noticed that pin 28 was was gone. Would that make the engine stop running? It turns over but wont start.
    Also fuse # 18 in the E30 fuse box was burnt out, replaced but still wont start, not sure if its related
    any input would be appreciated
    thanks
  • kevmo707
    • 62
    ohh btw the wire that goes to the pin is brown/orange and called the Sheild Ground if that at all helps
    • bwh13
      • Jan 2007
      • 437
      It looks like that ground is for the Crank position sensor, so if that doesn't have a ground it won't tell the DME to fire the coils...
