I had mine welded for a quick solution but what are you guys using to allow the mid pipes to disconnect from the headers?
headers- how are you fitting mid pipes to them?
Tags: None -
The ebay headers are 1.75'' and 2.0'', I had them cut back so they are both 2.0'' out. This goes into an SPD merge (dual 2'' in to single 3'' out) with one leg welded to the header and a clamp on the other so they can be removed later on. I then have a v-band at the 3'' end of the merge and is 3'' stainless all the way back. Hope that helps.Comment
