S50 Valve Retainers
  • Mstngcobr761
    • Apr 2008
    • 557
    S50 Valve Retainers
    Read in the thread thats stickied at the top that pre 10/95 S50s have had valve retainers have had some problems. Have any of you guys experienced it? Did you upgrade your retainers or just let it go? With my engine coming together w/ alot of money into it would hate to have these fail
    Thanks in advance
  • FredK
    • 14745
    I pulled the retainers in a 7/95 S50, and they looked fine. I replaced them with the updated pieces. I'm not sure what you've put into your engine, but if you already have the tools, replacing the top spring plates and collets costs around $150 in parts.
    I'd rather not drop a valve. The best case scenario is an HG job, and R&Ring the dropped valve and seat, if the valve doesn't hit the cylinder wall by some miracle.
    • Mstngcobr761
      • Apr 2008
      • 557
      I can do them if its only 150 dollars I woud like to know I dont have to worry bout them
      • lennon
        • Jun 2008
        • 1416
        i bought the 'updated' ones for my motor. the motor had well over 100k on it and the 'old style' hadnt failed yet, i just did it for peace of mind just like a hundred other things on the motor.
        • Mstngcobr761
          • Apr 2008
          • 557
          yea the more i get into my motor i feel like I need to do everything for peace of mind hah
          • lennon
            • Jun 2008
            • 1416
            yes ive spent plenty on peace of mind. do you have a build thread? what are you doing to the s50?
            • e30s52
              • Oct 2007
              • 5235
              Thanks in advance
              Its 150 bucks for piece of mind. Just do them. It will be alot cheaper then dropping a valve.
              www.gutenparts.com
              • mazur
                • Jan 2006
                • 731
                Retainers fail catastrophically. So the people saying that they looked okay means nothing.
                Just go ahead and replace them.
                • jrdeamicis
                  • Nov 2008
                  • 956
                  I replaced mine with the updated parts. I see no reason to NOT replace them.
                  Past Car : E30 S50 6 Speed 5 Lug 3.73
                  Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                  ___________________________________________
                  BNB Designs
                  Engine Swaps, Fabrication, Innovation, General Repair
                  Richmond CA
                  Julian 848-248-8029
                  • AlarmedBread
                    • Sep 2006
                    • 1510
                    Does anyone have a side by side of the two types? Easy way to identify if they are updated or not?
                    Thanks
                    • jrdeamicis
                      • Nov 2008
                      • 956
                      Thanks
                      Not really. No.
                      BNB Designs
                      Richmond CA
                      Julian 848-248-8029
                      • Mstngcobr761
                        • Apr 2008
                        • 557
                        Originally posted by jrdeamicis
                        Not really. No.
                        The part numbers remained the same too
