M50TU help
    M50TU help
    i have my 93 m50 i need the IAC valve everyone(kragen, autozone, napa) pulls up a 3 pin connector my harness is a 2 pin connector does anyone know why this is or were i can find the IAC i need
    "God created turbo lag to give V8's a chance" Taylor D.
    You sure you have the right plug? should be a 3 pin...
      ICV is 3 pin on all m50's
        what is the plug that is on the same strand of harness as the maf plug with 2 pin than?
          That is for the charcoal canister valve.
            dude i feel like a dipshit i just realized the iac was totally behind the coolant hoses an wire harness, thanks alot lol i just needed to look at the motor an it came to me
              yes, you need the purge valve for the 2 prong paired with the maf wire.
              #1 there
              Full Build Thread Here
                lookin for the height messurements on a 535i engine mount if anyone has one out to messure for installed height, i was guna use my e30 mounts (they were brand new but they are too short) and now the motor is in but chillin on my jack untill i get some or make aluminum ones but i need the hieght an no parts store nor the dealer has one for mock up
