i just took off my TB and i noticed a lot of oil in my m50s intake. the TB even had oil in it. what would cause this? thanks.
engine oil in intake mani.
Tags: None
That's my vote. If you have that much I cannot see it being anything else. Doing a catch can setup or just not routing it into the intake at all (then it should go into the exhaust) are your only options.
On another note though, I once had oil buildup nearer the ports of my manifold and on the backside of my intake valves cause by old valve seals.
Small chances but I have seen that before and problem was in piston rings... Compression in the oil pan lifts up too much oil bla bla... But it was GTI not bimmer:-)Comment
