Looked thru all the posts and didin't see an answer to this question:
If the cruise control and OBC are gone, will the speed signal still get to the DME?
As I understand it the speed signal goes from the sending unit ---> speedo ---> cruise control unit ---> OBC ---> DME
The CEL started coming on intermittantly a few months ago but I thought it was connected to the knock sensor wiring problem I had. Didn't see it at all for 6 months after getting the car running. Have the 88 325i S52 OBD1 with E34 harness with Treehouse adapter.
When I swapped in the 3.07 rear diff the speed sensor CEL came on using the stock E30 sending unit. Checked the plug and couldn't see anything wrong. I swapped in the Z3 sending unit and cleared the CEL. Now the CEL comes on after about 50 miles of driving.
