Is a single 2.25" exh. too small for an s52?
  • Adrian_Visser
    • Jun 2006
    • 2823
    As the title says, my 325is has a new custom 2.25 single pipe exhaust with 2.25" cat and a resonator after the cat to magnaflow 14815 muffler, it is loud with the m20, but will I be losing alot of power with the S52 if I use this?
    '89 Alpine S52 with goodies
  • 318isbmw
    • Nov 2005
    • 2841
    I think its definitely pushing it in terms of diameter, I would go 2.5 personally, but it doesn't hurt to bolt it up and see how it feels. Worst case take it off and do 2.5. I think my m42 had a single 2.25 so that's my reasoning for saying 2.5 would be better.
    • e30polak
      • 6136
      Considering that a stock s52 exhaust is dual 2" (I think), I'd say ya it's too small. 2.5" is a good size, that's what most of us run.
      INSTAGRAM: @UNDR8D_EMPIRE
      • Adrian_Visser
        • Jun 2006
        • 2823
        fair enough thanks for the advice, adding exhaust to parts list.
        • Mr Two
          • Jul 2008
          • 590
          I thought stock was closer to dual 2.25" OD?
          My personal aim was for dual 60mm, or around 2.36"
          • ColdAccord
            • 5926
            I'd like to make myself an exhaust. I'm running e36m3 currently, that bish is heavy as hell.
            single 2.5 is kosher?
            Originally posted by blunt
              • 37832
              I think single 2.5 is a good way to go.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • daniel
                • 6703
                i have single 2.5 with magnaflow in the back. sounds great but it is really raspy at full throttle, even after putting like 10k miles on the car. i hate it.
                http://instagram.com/dslovn.drives
                • matt
                  • 3731
                  It doesn't really matter.
                  Stock is not even dual 2" BTW. It's dual wall pipe, the outside is just a heat shield.
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    Okay I think I read something like that it is 40mm inner wall or something isn't it? maybe 44mm I might be mixing up stock e30 and stock e36 M3 sizing fuck I must of spent an hour and a half reading various posts about this shit and now I can't remember it aghh. I know I have read several good threads about what is the perfect 24v rasp free exhaust but all the searching I did didn't turn up the threads I wanted to re-read. So single 2.5 will still give you rasp? does a dual with a x-pipe have alot less rasp than a dual w/o? I always thought that a proper x-pipe would cut down the shit sound alot.
                    then a y-pipe into single doesn't do the ame job i guess eh?
                    • e30polak
                      • 6136
                      Rasp is more over the cause of thin walled ebay headers and raspy mufflers like Magnaflow. Mine is only raspy when I let off the throttle at high rpms and up top. I'm running a Vibrant muffler and a Borla in the middle:
                      • Mako18
                        • Jul 2006
                        • 688
                        My M roadster has dual 2.25 (OD looks closer to 2.5) exhaust.
                          • 37832
                          http://www.youtube.com/watch?v=r2H5YreLZqk
                          I still want to swap a Vibrant on to my car!
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • 7pilot
                            • 475
                            Yes.
                            A good 1.8 can use 2.25"
                            A 2.0 can use 2.25 before cams.
                            You'll be choking a 3.2.
                            A stock BMW 2.3l s14 is using dual 1 7/8" pipes to handle 195 to 240 hp flywheel.
                            The s52 will run like an Eta :yawn:
                            m
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              Haha well I don't want that now do I.
