Flex guibo for m50 trans to e30 m3 driveshaft???
  • TheBANKe30
    • Nov 2009
    • 103
    which damn flex guibo do i need for my m50 swap.
    i have my e30 m3 driveshaft ready for install , but it doesn't match up to the m50 transmision flex guibo
    do i need the 96mm one from an e30 m3 or e36 328's or the weird larger one people talk about .
    what is the best differential for me to match the e30 m3 driveline with also!?
    need help. i wanna drive this beast
    95' e36 325i manual 102k - dead and parted
    87' e30 325i manual m50 102k - alive again
    89' e30 325i coupe manual 162k - acquired june. 2009
    sold dec. 2009
    88' e30 325ix coupe manual 182k
    " Everything happens in series of three "
    e30 all day
  • FredK
    • 14762
    The 96mm is the larger of the two guibos. The other is 78mm.
    A 96mm E30 M3 or E36 M3/328 guibo will work with the E30 M3 driveshaft.
    What transmission are you using?
    • Jason89i
      • Sep 2004
      • 875
      if your using the m50 trans (getrag out of an e36 318 / 325) then you use the e30 325 driveshaft with the smaller guibo. getrag output flange is small.
      if your unsing the s50 / s52 / m52 trans (zf out of an m3 / 328) then you use the e30m3 driveshaft with larger guibo. zf output flange is large.
      cheers, jason
      • etxxz
        • Feb 2006
        • 2085
        you can also use the M3/328 driveshaft and guibo with the ZF tranny. These driveshafts are good length wise and have the 4-bolt diff flange for our diffs.
        This is what i'm using.
        No more e30s for me.
        88 black BMW OBDII 332is dedicated track [sold]
        88 BMW OBDII bronzit 332is [RIP 03/08]
        91 BMW 325i [sold]
        86 Corolla 'Ae86' HB 20v trd [sold]
        http://youtube.com/watch?v=pTj7Hn9v5Rs
