UUC shifter questions
  • bwh13
    • Jan 2007
    • 437
    Looking at which UUC kit would be the best fit for the E30, and if they are interchangeable between the different trannies. Have the S52 w/G250 now.
    I might get a ZF trans later and don't want to blow $$$ on a shifter and then need to get another if I decide to swap.
    Anyone have any info?
  • sharky
    • Jan 2005
    • 2672
    I run a UUC Evo 3 w/ the ZF
    • matt
      • 3732
      Call them and ask. I know Rob from UUC has a swapped e30 so he may know what you need straight out.
      • kuzimmer
        • Apr 2008
        • 93
        If you look at a G250 short shifter and a stock E36 ZF shifter, you will notice that the distance from the ball section to the shift shaft connector is almost exactly the same. Thus if you buy a short shifter for a G250 then switch it over to an E36 tranny, you will no longer have a short shifter. BTDT.
        Kurt---no longer has an SS :(
