s50 strangeness
  • rede30
    • 4697
    s50 strangeness
    I was driving the s50 car today, picking up a rear seat from 884door, and I had some s50 failure. My idle started to jump around a bit when stopped, but it wasn't to extreme, just not a perfect idle. Then when I was nearing home the motor stuttered on a harder acceleration, power stopped at like 4K and it was enough to where I felt lots of forward force from in my seat. It kicked back in for a little while then for about a quarter mile it felt like I was running on 5 cyl. Then it kicked back in as I was arriving home and when I pulled it into the garage I let it idle for a second, which it did fine, but then the idle went crazy and the car actually reved pretty high so I shut it off and when I opened the hood there was lots of smoke coming from the back left corner around the brake booster with a burning plastic smell attached to it. What is burning, why am I loosing power because of it, and why is my idle crazy?
    aaaaaah
    I will dive in a little ways tomorrow morning but I was just checking here first.
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Melted a vac hose?
    • rede30
      • 4697
      could it be something electrical and I just melted a wire?
      • OrganicMechanic
        • Jan 2008
        • 1719
        join the E30 Cabrio owners gruppe
        click here for details
        • rede30
          • 4697
          this.
          I traced one exploded ground wire from one of the three relays that are external in the engine bay- I forget which one it is. The wire is obviously melted all the way to the dme and took some wires with it. When I get to the plug I can't even tell what is going on, it's a mess. I am going to look for a new harness, this one was a hack job from the start.
          So I guess now I need to trace some wires to make sure I don't do this again, i don't enjoy the thought of this next step. Any thoughts as to what would cause this meltdown?
          organic, tell me more. I didn't quite get what the link you gave me says. I see similarities.
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            Wow. I'd get a meter out and check everything on the new harness before installing it...
            • rede30
              • 4697
              are m50vanos/s50 harnesses the same?
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Yes. Try for e36 over e34 for the extra length to get it into the dme mount in the glovebox.
                • etxxz
                  • Feb 2006
                  • 2085
                  looks like a power wire was grounded... or squished, or found itsway under a bolt or something so to go to a chassis ground. i had a similar issue with a wire coming from the dme got cought under one of the dme mount bolts. it smked a bit, i smelled it and shut the car off. it was easy to trace thankfully. moved it, no problems since. [knocking on wood]
                  No more e30s for me.
                  88 black BMW OBDII 332is dedicated track [sold]
                  88 BMW OBDII bronzit 332is [RIP 03/08]
                  91 BMW 325i [sold]
                  86 Corolla 'Ae86' HB 20v trd [sold]
                  http://youtube.com/watch?v=pTj7Hn9v5Rs
                  • rede30
                    • 4697
                    I just replaced a heater core valve and messed around with my gauge pod, I am going look over my work and see if I grounded a power wire.
                    • lennon
                      • Jun 2008
                      • 1416
                      man that sucks! hopefully you get ahold of an unmolested harness this time and you shouldnt have any problems.
                      • rede30
                        • 4697
                        I just ordered one from speedminded from here on the forums. I will probably pull the intake manifold when I replace it, or not. In my head it sounds like less of a headache to pull the mani.
                        • M-technik-3
                          • 18946
                          Thinking rubbing factor caused short and resulted in overheating of wires.
                          • rede30
                            • 4697
                            rubbing factor?
                            • Jean
                              • 18228
                              Nasty, good thing it didn't start a fire
