S50 not running right
  • cheades
    • 632
    Ok, the car was running perfect and I stopped and shut the car off. Came out 15min later and it would roll over and start but immediately die. I can get it to run, but just barely and it sounds like it is running on 4 cyl. Tried pulling the MAF and it changed it just enough to where it would barely idle (jumping from almost dead to 2k and back).
    I can't do the stomp test as that doesn't work in my e30 and I don't have a code reader handy. Any diagnostic help if you have experienced this would be great.
    Craig
  • yert315
    • 2734
    check for vac leaks. On my m50, there was a plastic hose (can't remember what it was) under the intake manifold that popped off and caused similar symptoms.
    • 87e30
      • Jul 2008
      • 5676
      Yup, check the hose on the intake tube too, perhaps that has come loose.
      I just hate everyone.
      No need for discretion.
      • cheades
        • 632
        Yeah, just got it in the garage and was able to look better, the stupid ICV hose on the intake manifold had just barely backed out.
        Thanks for the quick replies.
