Hi all
I recently bought an all-aluminium M52B28 from an automatic 1997 328i, with 98'000 miles on the clock. I'll happily admit that I know nothing about engine building, engine maintenance, or electronics, so I'm going to use this topic to get your help. I want to learn about all of this!
I'll be putting this into my 1984 323i in a few months time. Unfortunately I have to sort out bodywork and rust issues first, but while it's in the shop I want to get this engine 100% ready.
I bought it from a guy who assured me that it had everything on it, and when it arrived here I discovered 1) no alternator 2) no aircon (don't want aircon anyway) 3) no plugs (well actually one plug) 4) no coils 5) no belts. That's what I've discoverd so far. It came at a very low price, so I'm not complaining, however I will be getting the coils and plugs from him in early January. When I took off the cylinder head cover (which had 4 missing nuts) I discovered lots of brown sludge, some scuffed cam lobes, and only one camshaft cover (unless there's only supposed to be one?). There's also two missing bolts on the intake, so it's pretty clear that the PO took off the head to mess around, which is a bit worrying. Anything I should check?
What would you do to this engine? Anything I should replace? Is it worthwhile removing the head to have it cleaned and check everything out? What are the usual maintenance items? Gaskets, bearings, whatever. I'd like this engine to be running almost perfectly by the time it's needed. :) So please chime in on what you'd do if this engine arrived on your doorstep this morning.
I'm on it! So you think this needs to be removed and properly cleaned?
