octane?
  • D-rock
    • 714
    octane?
    M50 swap. I am having fuel problems. Car was starting then died when I pressed down on the gas. Now the car is not starting at all. Could this be cause I am using 93 octane?
    Thanks!
  • matt
    • 3732
    No.
    • D-rock
      • 714
      I am going to check fuel pump and lines tom. Anything else to look into?
      • BlUe E30
        • Jun 2008
        • 180
        you were very vague. any other info you can give?
        • FredK
          • 14763
          You probably hooked the supply and return lines backwards.
          • M-technik-3
            • 18946
            Way to vague, seriously we are stabbing in the dark.
            • D-rock
              • 714
              no
              Car was working fine. I turned it off. Went back to my car an hour later. It started but was idling at under 500rmps. I pressed the gas and then the car died. Later that day it was only cranking and not starting. Thats all the info i have! :/
              • M-technik-3
                • 18946
                Decent charging system? Battery is strong not weak? How long has the car been running? or is still in process of being built?
                Fuel filter? Fuel pumps running?
                • matt
                  • 3732
                  Air leaks.
                  • D-rock
                    • 714
                    Baattery is new. Car has been running fine for 3 months and out of no where this happens. Also going to check filter and fuel pump tom.
                    • lennon
                      • Jun 2008
                      • 1416
                      Originally posted by matt
                      Air leaks.
                      +1 even though this guy is vague as fuck so who knows
                      • surebimmer
                        • Jan 2004
                        • 978
                        Check the icv tube to the manifold. Just my air leak guess.
                        • D-rock
                          • 714
                          How I am I vague I have no moke info.
                          Will be checking gas flow and filters tom. If all is okay then I am guessing it will be an air leak.
                          • M-technik-3
                            • 18946
                            Also check the HFM by disconnecting it. Try starting that way, if it starts it's the hfm.
                            • jonmon6691
                              • Aug 2009
                              • 252
                              Did you do the swap yourself or did you buy it that way?
                              <-- F*** that guy
