Hey guys,
So I've completed my swap and the engine is running pretty smooth. Specs below:
-stock s52 converted to OBD1
-getrag 260 tranny
-m50 manifold
-obd1 exhaust manifolds and midpipe
-3.5" bosch MAF
-TRM off the shelf chip for the above mods
Problem is that I keep getting a check engine light when I rev it pass 3k rpms or so. I have carsoft and scan the code in the DME and I get
-Cleared the CEL.
-Fire up the engine, no CEL. Scan for codes, no codes.
-Rev it up to 3k rpms or so, CEL comes on.
-Scan for code and get the above code.
-Turn off car.
-Turn the key to ON position but do not fire up the car. Scan for codes, no codes.
-Fire up the car again, CEL is still on. Scan for codes, same 252 code.
It only detects this code when the car is fired up and running. If I don't fire up the engine and just have the key in the ON position, then it doesn't detect the code.
I've tried replacing the charcoal canister purge valve with a different one, still no luck. I've tried checking for vacuum leaks with carb cleaner but nothing noticeable, especially around the charcoal canister area and the throttle body housing.
Any other ideas guys?
-getrag 260 tranny
-m50 manifold
-3.5" bosch MAF
252 Tank Ventilation System
-Turn off car.
