M50 cam options
    M50 cam options
    I´ve got a single vanos head without cams.
    What are my cam options, can I install non vanos cams?
    Or must I get cams from single vanos engines?
    I don´t have the vanos unit and don´t really want it. So the cam timing will be fixed.
    I don´t need to hear about the joys of having vanos. I just need to hear what exactly can be installed there that comes from a M50 based engine(no US S50/S52 here in the UK mind you)
    Gunni
    @ Prodrive / Aston Martin Racing
    According to this thread I can use non vanos cams when using non vanos lifters and trays.
    So I think I´ll be sourcing 320i intake cams as they are the same 240deg duration as non vanos m50 ones, they are just timed 6deg different. I was going to mod the timing gear anyway to allow me to set the powerband as best as possible.
    If anybody has any further info I´d like to hear it.
    Gunni
      dual NV intake cams will give you 240/240. i don't know how to time that tho.
      Almost anything will work as long as you have the trays/lifters with it.
        Well I´ll use a dial gauge and time it as suggested by catcams website or equivalent.
        i.e
        lift at TDC. Should be pretty easy.
        Gunni
          i have a set of good s50 cams that i am willing to get rid of for the right price
            I don´t have the budget to ship cams between countries.
            240deg cams will do fine for 500hp anyway.
            Thanks.
            Gunni
              and boost, I imagine?
              1989 cirrisblau-metallic 325i
                I´m hoping to stay below 1.5bar boost.
                Gunni
