Matching ZF trans with clutch options
  • m_dudey
    • 267
    Originally posted by herlsy
    Ok still unsure about this since i haven't seen anyone confirm they are using it. Anyone out there using this combo? Just a last check before i ditch it all and go with m50 parts. Cheers.
    Flywheel: m20 (325i e30)
    Clutch pressure plate: e30 325i
    Clutch disk: e30 325i
    Throwout bearing: e30 325i
    Pilot bearing: e34 525i (zf)
    I'm thinking the main thing i'm unsure about is the throwout bearing.
    bumping this.
    I'm in the same situation. I have a G260 right now and about to replace it with the ZF.
    I assume that I'll be using the ZF release fork lever?
    Still planning to use the m20 flywheel, pressure plate, clutch, and starter.
    Obviously I need a new pilot bearing for the ZF.
    But what about the throwout bearing? Do I use the one from the ZF or the G260?
    Also, which clutch slave cylinder will be appropriate?
    herlsy, what was your final setup?
    • Supadave
      • 1006
      bump
      https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
      • Jand3rson
        • 37587
        Originally posted by JGood
        I had a local machine shop do it for about $50. It came back fully cleaned and new looking. I think I had him cut it down about 6mm.
        Mine was $86, but they also did a full resurfacing job on it. I had them take the mass on the backside down to about 1mm above the ring gear.
        • herlsy
          • Sep 2009
          • 339
          I used:
          ZF310
          m20 Single Mass Flywheel (shaved off the backside)
          m20 325i Pressure Plate, Disc, Throwout bearing
          Larger inside diameter pilot bearing (from 1992 525i)
          • m_dudey
            • 267
            I used:
            ZF310
            which clutch slave cylinder?
            • Jand3rson
              • 37587
              Whichever one goes with that trans.
              • m_dudey
                • 267
                so it'd be the ZF clutch slave cylinder. but more specifically, the m3 clutch slave or the non-M clutch slave? which one will work better with the m20 clutch components?
                • herlsy
                  • Sep 2009
                  • 339
                  I used a clutch slave part # 21526775924
                  • ACHTUNG
                    • May 2005
                    • 2397
                    A bit off topic but why did you guys decide to swap the G260 for the ZF?
                    1989 US E30 Cammed S52
                    Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                    • herlsy
                      • Sep 2009
                      • 339
                      Didn't want to mess with the trans brace/shift linkage, and came across a zf310 for cheap.
                      • m_dudey
                        • 267
                        how's the clutch engagement point? right off the floor, just right, or way up high?
                        also, how stiff is it?
