i couldnt find any info searching but maybe i just missed it, i was also on all-data (no-data) for hours looking thoughwireing diagrams with no luck so if you guys can help i thank you.
i have a 86 325es, swapped in is a turbod m50tu with getrag 250 out of a 525i but has a e36 325i harness. so i ditched the dual pump setup and am installing a single walbro intank pump. i hooked the ecu up and turned the key to on (not cranking since it doesnt have oil yet) and had my dmm and got no voltage at the pump, i checked both the intank and inline pump wires.
i first assumed it was my c101/x20 connector so i checked everything there. is pin 13 on the e30 connector a ground for a relay or to the ecu cause it doesnt put out any voltage? i tried pin 13 on the harness to pin 6(12.5v) on the connector also with no luck. no fuses are blown. i need this thing runnig asap. thanks
