M50NV Idle drops on deceleration
  • Kerrath
    • Jun 2008
    • 577
    I've searched.
    1992 E34 M50.
    Recently, I've had an issue with my idle dropping significantly when I start decelerating. It pretty much only happens when moving and doesn't matter whether warm or not. It's bearable, doesn't impair driving, just is mildly annoying. To the best of my knowledge, there are no vacuum leaks, but I don't have a vacuum gauge to test.
    Additionally, my idle is about 500 RPM when it is supposed to be more like 750. It's a little bit rough.
    Pertinent information that is known:
    New O2 sensor (<5,000 miles)
    Good ICV
    Good MAF
    Adjusted/Tested TPS
    Any help is appreciated. Thanks.
  • SamE30e
    • Sep 2007
    • 4319
    The tach is off by a certain % I forget what it is. But my tach says 500, but it is at like 700ish
    1985 325e 2.8 Turbo VEMS
    • Kerrath
      • Jun 2008
      • 577
      Why do you say that? It makes no sense unless you have a 9k tach or something.
      • Wh33lhop
        • 11705
        Ehh 200rpm is a pretty big percentage of 700rpm. Does your tach read 5 grand when you're at 7?
        My tach has always been absolutely spot-on with the M20, much more so than previous cars. It gets a little bobby at times though.
        paint sucks
        • screwbiedoo15
          • Aug 2009
          • 79
          I haven't noticed the idle dropping on my m50NV when decelerating but my engine does idle at 500rpm as well. Also curious if this is normal or problematic?
          • Kerrath
            • Jun 2008
            • 577
            It doesn't really hinder the driveability, it's just a mild annoyance. The idle drop on mine is a major annoyance.
            That's how I feel. I dont see any way that my tach is wrong there when the revlimit is exactly where it's supposed to be.
            • MattM
              • Apr 2009
              • 931
              mine idles at 500 when its been sitting running for awhile. idles at ~1100 when moving, and ~700 when cold
              Full Build Thread Here
              • Kerrath
                • Jun 2008
                • 577
                Yeah, when I first start it, it hangs at about 750 for a bit, then settles to 500.
                K, so I guess we've established that 500 is essentially normal for us, but anyone have advice on the idle drop on deceleration and the sort of roughness when at idle?
                • derrith
                  • May 2008
                  • 77
                  Any vacuum leaks? I hastily swapped a NVm50 into my old 528e and had no end to idle issues. I ended up replacing all the vacuum hoses and the intake manifold gaskets and that fixed it. The lines to and from my ICV were especially bad.
                  1983 635csi
                  1988 M5
                  1991 850i
                  • jonmon6691
                    • Aug 2009
                    • 252
                    You could leave it in gear when you decelerate...
                    <-- F*** that guy
                    • 416stroker
                      • May 2008
                      • 2448
                      Mine does it to only with the lights on. but it idles at 500 as well.
                      How rough? Mines my flywheel what are you running for a flywheel?
                      84 318I Delphin RIP
                      87 325IS delphin 24v Sold
                      89 325 Alpineweiss
                      • Kerrath
                        • Jun 2008
                        • 577
                        I can feel it in the car and hear it in the exhaust, even though the idle fluctuates no more than 10rpm. Also sometimes at night I notice it having an effect on the brightness of the dash lights.
                        I'm running E34 single mass flywheel.
                        • Wh33lhop
                          • 11705
                          I just hooked up my tach, it idles around 650-700. I've also got a broken PCV hose and a crappy idle most likely due to that, although it hasn't died on me yet. It's a non-vanos out of a '92 (I believe) E34 using a lightened M20 flywheel. Honestly I think the IM is resting on the brake booster (E32 booster) and I haven't had a chance to shim the motor mounts yet, so that may have to do with it too.
                          paint sucks
                          • Kerrath
                            • Jun 2008
                            • 577
                            How do you think the booster is affecting your idle? And I wrapped the parts of my PCV hose that seem to have issues and it had no effect on my idle that I could find.
                            I didn't notice this post before.
                            You could also stall every time you get to a stop light. It's not an option.
                            • Wh33lhop
                              • 11705
                              literally the PCV hose won't fit on the nipple. It's torn and too short now.
                              The IM, being plastic, seems a bit distorted, so it might be boning up the IM gasket-to-head contact. I should also mention that I'm not yet running an O2 sensor..
                              paint sucks
