typical wiring/starting issues
  • rede30
    • 4697
    I have all my connecters hooked up right, or at least I would expect this to be true after testing wires and looking at diagrams. I also have my 101-x20 wiring done but I don't have power past my fuel pump relay. I know some things like my CPS being connected wrong would make the DME not send ground my relays but is there anything on my 101/20 adaptor that would cause this? I have yet to run back over my 101/20 work but i was just wondering. It doesnt seem like you would need many of the adapter wires to run the motor.
    I am also using a auto harness, whats the deal with the whole PIN 26 to a red/white main relay wire.
    edit* I had something on my c101/x20 points wrong. small green wire off e30#7 and e36#56 and i forgot some other wire dealing with the o2.
