Putting M50 and Trand in tonight!! Am I overlooking anything??
  • isolatos
    • Dec 2009
    • 172
    I plan on putting the motor and trans in tonight(as one assembly). I just want to make sure I have everything in place. Here is what I have:
    93 M50:
    Ebay Header w/ BMW gaskets
    New spark plugs, valve cover gasket, oil pan gasket, fuel fliter, oil filter
    E34 525i oil pan, dipstick tube, dipstick, oil pickup tube,throttle cable
    E36 engine mount arms
    E28 535i motor mounts
    E30 starter
    E30 radiator and hoses
    E30 flywheel lightened, balanced and resurfaced, Sachs kit with alignment tool and pilot bearing
    New slave, master and line for clutch
    E21 modified booster
    replaced shifter bushings
    5 hours of ETM work for harness(if all is good on the harness I will remove it and install pins in the right location)
    White325is trans crossmember
    I think that is it.
    Am I missing anything?
    Thanks
