its been awhile now since i swapped the M50 in my car, everything is good except i get a small vibration at lower RPM's in each gear. im using the gatrag 260 with stock drive shafts and a 4:10 lsd...i checked the vibration dampener it was a rotted POS so i chucked it calmed down the vibration some but not all the way. Any one got an idea?
Drive train vibration
all checked out fine...kinda the only thing i am concerned of is the drive shaft not being straight when i did the M50 i made solid motor mounts, but i didnt have a e28 mount laying around for proper height so i guessed. it worked does not hit the oil pan nor too high but the motor/trans angle may be slightly F*ed off, anyone know the angle it should sit?"God created turbo lag to give V8's a chance" Taylor D.
my apologies i meant to mention this too im using solid trans mounts as well as motor mounts, i racked it like 6 times tryin to find out what was wrong but with out a angle gauge i cant tell if its off or not eye balled looks fine but you know how that goes"God created turbo lag to give V8's a chance" Taylor D.
Wait, you've got solid metal mounts and you're wondering why your car is vibrating?
Edit: I assume you mean more of a low-frequency oscillation ("vum-vum-vum") than a vibration. Does it do it in neutral? I recently shimmed the motor mounts without shimming the trans mounts (not even sure how you'd do that, seeing as the trans mount studs are so short) and I think I'm getting what I think is a little guibo shimmy around 2k in second and sometimes third. Interestingly, it goes away at higher RPMs and is not present in 4th or 5th.Last edited by Wh33lhop; 01-20-2010, 06:26 PM.paint sucksComment
check a loose bolt in the guibo that was my problem at low R's and when slowing downsigpic
^Back in the game^
BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
FS thread:
http://www.r3vlimited.com/board/showthread.php?t=214105Comment
It's the fact you are using SOLID trans mounts.
They transmit a TON of NVH into the cabin. You'll have to deal with it or change them out.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
^^ or this lol i forgot about ur solid mountssigpic
^Back in the game^
FS thread:
^That's going on the assumption that everything else is good like he says.
But seriously solid trans mounts are not ideal for a street car, I'd never do that again.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Forgot to post up what the prob was and my correction. So when I was doing the swap my friend thought we were going to pull the trans out(which we didn't, but while I was prep'n the motor to go in, he loosened the guibo, so 3 of the 6 bolts were loose causing the vibration, it was NOT from solid mounts...I do know the difference between harmonics and a violent vibration. Tightened up the bolts and was good to go. Solved this along time ago just went to the back of my mind"God created turbo lag to give V8's a chance" Taylor D.
