NV M50 to S50
  • MR E30 325is
    • Dec 2008
    • 3299
    NV M50 to S50
    Alright, I was changing the spark plugs today, and I discovered some very depressing news. The swapped E30 I bought half a year ago has some bad oil problems. There was a puddle of oil in the spark plug hole, and the plugs were soaked in oil.
    So, needless to say, I was looking for a reason to get rid of the M50 and get a little more kick from an S50.
    My question is (I have done some research about swaps, but I could definitely have more knowledge on the subject) what do I need to do in order to swap an S50 into my E30.
    Some info on the car.
    - Wiring was all done by the PO, and he did a good job, but it isnt done with a simple connector some members make, and I am not confident with wiring.
    - Has the M5 motor mounts, and the appropriate oil pan to make it work.
    - E21 brake booster
    - E36 transmission mated to the M50
    It has all the things done to it in order to make the M50 work.
    If you have any questions or need more info please feel free to ask.
    So, can anyone give me a list, or point me in the right direction to find a list of items I am going to need? The E30 wants to step up and run with the big boys.
    TIA
    My previous build (currently E30-less)
    http://www.r3vlimited.com/board/showthread.php?t=170390
    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
  • White325is
    • Oct 2006
    • 5947
    have you ever thought about replacing the valve cover gasket seals first?
    The oil could of filled the plug hole and when you pulled the plug out it would have got on the tip.
    Anyways if you have a NV M50 and you want to go to S50 your gonna need a complete S50 drop out and just switch your oil pan over.
    • 416stroker
      • May 2008
      • 2448
      A nonvanos Harnes & ecu are no good for any vanos motor.
      Change you valve cover gaskets
      84 318I Delphin RIP
      87 325IS delphin 24v Sold
      89 325 Alpineweiss
      • sharky
        • Jan 2005
        • 2672
        replace VCG, go turbo NV m50
        • richardb
          • 2121
          +1 on the valve cover... they go bad and leak oil down into the plug holes, then when you remove a plug it will get coated with oil & the socket. No reason for alarm...yet!
          Transaction Feedback!
          • StereoInstaller1
            GAS
            • 22679
            Yeah, those guys are full of shit.
            You got oil on your spark plug, that motor is trash. The harness, ECU, oil pan, clutch, brake booster, none of that shit will work on your new motor.
            Now that you know the truth, I will offer to get all that shit off your hands.
            $450 shipped should cover it.
            Go get to getting that stuff out of the car, time to go play with the big boys now.
            Closing SOON!
            Thanks for 10 years of fun!
            • 416stroker
              • May 2008
              • 2448
              84 318I Delphin RIP
              89 325 Alpineweiss
              • Uber E30
                • 1409
                boost is not an easy option in cali =[
                -Alex
                • skatebline
                  • Sep 2006
                  • 167
                  why not>?
                  • hugh jass
                    • 2220
                    Originally posted by skatebline
                    why not>?
                    smog tests
                    ______________________
                    ex-Chief Operating Officer
                    Blunt Tech Industries
                    West Coast and Pacific Rim
                    • Atreus
                      • 1846
                      I'll pay you 460 for it. I'm doing you a huge favor getting rid of that toasted motor...
                      KTHXBYE
                      1991 325iC - Mauritsblau sumthin metallic blue. DEAD
                      1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
                      1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
                      1991 325iC - Calypsorot Metallic
                      1994 540i - Granitsilber
                      Originally posted by scabzzzz
                      I've had blunts cock in my mouth, but I'm not gay.
                      • Uber E30
                        • 1409
                        why not>?
                        Its not legal to run turbos on cars that didnt come OEM with them unless they are CARB certified... and AFAIK dinan is the only one$$$
                        -Alex
                        • skatebline
                          • Sep 2006
                          • 167
                          Damn that is shhhhhhhit Aaaaa!!!
                          • Uber E30
                            • 1409
                            Yeah, thats why SC's are better here, easy to take it back to stock in a few hours.
                            -Alex
                            • lifeiskaos
                              • 1709
                              and MechTech
