zf with m20 clutch setup?
  • e30turboboy
    • Jun 2008
    • 216
    With a 95 M3 S50 and Trans. Using a single mass M20 flywheel and clutch setup. Do you use the 260 slave or the m3 slave?
  • White325is
    • Oct 2006
    • 5947
    From what I have been reading, you use the slave for the trans you have.
    If you have a 240, you use a 240 slave.
    If you have a 250, you use a 250 slave.
    If you have a 260, you use a 260 slave.
    You get the idea.
    • MattM
      • Apr 2009
      • 931
      yeah use the Zf slave
      Full Build Thread Here
      • e30turboboy
        • Jun 2008
        • 216
        thanks
