can I put a non-vanos head on a vanos engine?
  • ScHpAnKy
    • 1573
    I'm looking at getting a 98 528i engine for cheap to put in my e30 318is, but don't want the added complexity of a vanos head - would a non-vanos head from a 92 m50 be direct fitment to a latter block, or no? If not, what would I need - also, would an auto's harness be identical to the manual? Looking to get everything I need from one parts car, and then the tranny back to the rear either new or from a junkyard.
    91 318i | 87 535iS
  • fiftytakedowns
    • 2460
    that an obd2 head as well
    [/url]
    Team USA Wrestling 67KG
    • ScHpAnKy
      • 1573
      I apologize for my naivety, but could you explain? If I went with the m50 non-vanos head, couldn't I run OBD1 - or do I not understand this correctly :o
      91 318i | 87 535iS
      • Pull_Addict
        • Jan 2008
        • 250
        just do the extra work and run vanos.
        • sharky
          • Jan 2005
          • 2672
          Yes you can, had a setup like that before in a E36. Not terribly difficult but you should just geta vanos head
          • ScHpAnKy
            • 1573
            you used the M50 non-vanos on a later block? What did you have to do to get it running?
            I'm curious about why everybody is recommending the vanos head, I'd already have one with a 98 528i engine but plan on boosting later on - and from what I've read the non-vanos head would obviously not have any vanos-ticking issues as well as stand up to more abuse - am I wrong, here?
            91 318i | 87 535iS
            • ScHpAnKy
              • 1573
              Is there megasquirt or similiar engine management for both fuel and spark for the vanos heads? Also, if the engine currently has vanos tick - would you still stay with that recommendation?
              BTW, I like your rear wing - is that a painted IS spoiler?
              Appreciate the info, guys - learning a lot, here :)
              91 318i | 87 535iS
              • Coyote_ar
                • Sep 2009
                • 175
                you can get a vanos delete kit, and that should solve the vanos issue for you.
                ---E30 320i Hennarot 1984 Sedan---
                • Pull_Addict
                  • Jan 2008
                  • 250
                  not too sure on the engine management part, but vanos tick wont be a hard fix. if you want to go turbo, a non vanos head would be the way to go.
                  its a mtech 1
                  • ScHpAnKy
                    • 1573
                    its a mtech 1
                    so as I understand it, M50 non-vanos with OBD1... any place like painless performance for bmw engines?
                    91 318i | 87 535iS
                    • sharky
                      • Jan 2005
                      • 2672
                      yes NV M50 head on a S52 bottom, OBD1 harness and sensors. I think it was the harmonic crank balancer that need to be changed out in order to recieve a crank signal. Chris Langsten bought the car from me after I couldnt get it started and he trouble shooted it to this if I recall.
                      • FredK
                        • 14761
                        Sadly, there is no Painless Performance for BMW engines. I wish. LOL.
                        • ScHpAnKy
                          • 1573
                          :( :( :( what reading would you recom. an amateur bmw guy for readingup on wiring up?
                          I noticed you're based out of mass - your car really is pure sex, what part are you from?
                          91 318i | 87 535iS
                          • FredK
                            • 14761
                            Actually, that quote was in reference to someone else's car! :D I just found the quote to be really funny.
                            Wiring a non-Vanos engine or a Vanos engine isn't that difficult with the factory wiring harness. Terminating the factory harness from the donor car with the proper connections for the E30 is slightly more difficult, but it is nothing you can't do after tracing a few items in a BMW Electrical Troubleshooting Manual.
                            You can get these manuals at http://www.wedophones.com/BMWManualsLead.htm
                            I'm from Southeast Mass.
                            • turbo325i
                              • Mar 2008
                              • 1143
                              ha ha. love it! were not working on old muscle cars here. too bad too because it they work nicely. :(
                              Turbo e30 M52. Built Motor, GT3582r
                              Watch my vids http://www.youtube.com/user/GrudgeRider156?feature=mhum
