OBD-II exhaust manifold material?
  • MatRacer
    • 562
    What is the material? can I weld on it?
    Thanks!
    E30 now S52
    2008 Suburban LTZ (Family and TT hauler)
    325xiT (Sold)
  • herlsy
    • Sep 2009
    • 339
    I believe its stainless steel, seems like it wouldnt be a problem to weld
    • justin_l_
      • Jun 2007
      • 1079
      Yes you can weld it. Hence welding up the air ports.
      • 87e30
        • Jul 2008
        • 5676
        Yes, mine has been cut and welded to clear the subframe.
        I just hate everyone.
        No need for discretion.
        • flyboyx
          • 8371
          they are stainless. I believe they are either inconel monel or a combinatio of the 2. They can be welded. 304 filler rod should be ok. I wouldn't use any other process other than a tig.
          Gigitty Gigitty!!!!
          • madjurgen
            • May 2005
            • 1203
            So attempting to MIG on these would end horribly?
            As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
            You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
            • flyboyx
              • 8371
              have you ever tried to mig thin wall stainless steel? If you only plan to weld up the emmissions ports on the flange, I think it would be fine. I am not a master welder, but I am very good at it. I would never attempt the tubes with a mig.
              Gigitty Gigitty!!!!
              • 325Projectz
                • Jan 2005
                • 1956
                the guy who welded my obd2 exhaust manifolds said if you can stick a magnet to stainless steel, then it can be mig welded, if not then use a tig. you can stick a magnet to obd2 manifolds...
                not sure if there is any truth to this but he used a mig to weld up them up, they turned out fine.
                91 m3
                • b*saint
                  • 3794
                  Factory inconel alloy? Post proof.
                  Ma che cazzo state dicendo? :|
