I have an s52 swapped into an e30 318i. The E34 cable doesn't look it will work without significant modification to the adjuster. Opened to the max the throttle body *still* doesn't close all the way. The guy who did the swap had to trim off a half inch (I learned this when I went to replace the sticking cable and ended up with an unhappy car with the throttle body cracked open by about 10%).
I've only seen a few mentions of "adjustments" to these cables. But is it a known fact that modification is required for the cables to work? Or is it supposed to be a drop-in replacement?
