My new turbo has arrived!
  • 01djb
    • 77
    Now will it fit under the hood?
  • Mstngcobr761
    • Apr 2008
    • 557
    Lol guess your the one with the t4 flange....that thing is HUGE
    • M-technik-3
      • 18946
      I'm guessing you should have checked that out prior to purchasing it correct?
      • 01djb
        • 77
        No , but i went to sears and got a hack saw Yeha!Yeha!J.K.
        Honestly,i think it will fit ,if i need to i can lower the engine about 1 inch..or maybe a hood scoop but i am not down with those really..
        B.
        • Adrian_Visser
          • Jun 2006
          • 2823
          if you lower your engine an inch your oil pan will be one inch closer to the ground...
          '89 Alpine S52 with goodies
          • M-technik-3
            • 18946
            And you will need to correct the rest of the drive train ie transmission mounts and possible a CSB might need to be lowered.
            On the off topic that thing looks it it was designed for a semi truck.
            • dranttna
              • 127
              damn thats gonna be fun to play with. what kind of "lag" are you expecting? are you going to run any type of anti-lag tuning or just use the thottle-to-the-floor anti-lag?
              and good luck with mounting, seems like it might want to poke out of the hood alittle bit
              325es/24v's/20psi/meth injection/
              • CorvallisBMW
                Long Schlong Longhammer
                • 13039
                Sweet baby jesus, that thing is huge.
                (that's what she said)
                • TopOfTheLine89
                  • Jun 2007
                  • 919
                  lagtacular! bet a lil t3/t4 would kill it.
                  97 tacoma 5 spd 4 cylinder
                  2001 330ci 5 speed
                  83 733i 5 speed, (FS)
                  • Alpina
                    • Oct 2004
                    • 838
                    Not quite,,
                    i did the same and have oem clearance,, from ground ,, but the engine is heavy and big and on some swaps YOU MUST do it ,, and imo a clever solution
                    take a look ,,
                    and it depends doing it right ,, for each swap , so in my case i just lowered the subframe from the body and the engine is in right position via the engine mounts
                    Sveinbjörn Hrafnsson
                    E30 CABRIO V12 M70B50 ///
                    ALPINA B10 BITURBO 346 @ 507
                    E34 550 V12 JML
                    Finnish wisdom : If you want to Win,, hire a Finn
                    http://alpina.123.is/pictures/
                    • 01djb
                      • 77
                      It should "light up "at about 5000 rpm If i need to i can always go with a 200 shot of nitrous to get it spooled at the line.(this is for a drag car obviously,don't try to put this on your mom's e30)
                      B.
                      • e30_325es
                        • 1249
                        Damn boris, that's ridiculous.
                        • rThor432
                          • Feb 2007
                          • 3907
                          When that thing spools up your location will no longer be "Earth".
                          • Wh33lhop
                            • 11705
                            Tectonic plates will be shifted, as will the earth's axis of rotation.
                            paint sucks
                            • rpm620
                              • 204
                              boris i know you sold me the holset to upgrade but DAMN man.. i wanna come over and check that shit out.
                              also drag car my ass.. lol... your going to rip ken and well everyone apart on the drives lol..
                              E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
                              *RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
