My recent s50 project is complete but i have a slightly rough idle and running, plus a check engine light. simple fix right, run the light, fix the issue.
i cant run it. my pin 15 is causing the GT1 to say low voltage pin 15.
when testing it with a multimeter it is reading only 9 volts. when tracing the wires it has one wire that runs to a non used pin on the wiring adapter to the chassis, and another that runs to the DME. I have swapped the DME with another and it still reads the same voltage.... what am i missing here.
