Knock Sensor Codes
  • nrubenstein
    • 3148
    Knock Sensor Codes
    So, I'm getting codes for both the front and rear knock sensors on the S50.
    Would having them hooked up backwards cause a code? (I guessed which plug to use when I hooked them up.)
    Is there anything else that I should check before I replace them?
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
  • sharky
    • Jan 2005
    • 2672
    are they cracked? you may have hooked them wrong, if you pull down the covering there is a blue mark on one and a yellow mark on another, they go specifically to front or back. Get the right orientation and torque too.
    • nrubenstein
      • 3148
      Perfect condition, they weren't a problem in the donor car.
      I guess I'll have to pull the manifold off and check them.
      • mega_t2008
        • Nov 2009
        • 43
        • Adrian_Visser
          • Jun 2006
          • 2823
          Hmm so the cracked and beat up looking ones I got along with my other OBD I sensors probably won't work then? I was going to cover them in silicone and see what happened...
          '89 Alpine S52 with goodies
          • sharky
            • Jan 2005
            • 2672
            I had a hell of a time getting used uncracked OBD1 sensors for my car, I went through atleast 6 or 8. Anyhow I had one good and one with a small crack that I epoxied. It has held fine but If I could do it again I would cough up the 150 or so for 2 new ones.
            • nrubenstein
              • 3148
              The annoying thing is that the sensors that I have are uncracked and and in great shape. I guess I'll make sure that they are plugged in correctly.
              Of course, I also have a DME code now. Second frigging DME, too. If I can just solve the stupid check engine light, I can get this thing registered.
              • BustaRhymes325i
                Gaping Anus OG
                • Aug 2009
                • 243
                Im hooking mine up right now on my s50, and I cannot differentiate between the 2. I pull back the boot, and they are 2 wires, one is black, one is clear. This is on both connectors. Can anyone verify how to tell which is front and which is rear?
                • samiam3356
                  • Jul 2009
                  • 1901
                  Continuity test.
                  Originally posted by Roysneon
                  $5 shipped?
                  Originally posted by MarkD
                  You are a strange dude, I'n not answering any more posts from you.
                  • BustaRhymes325i
                    Gaping Anus OG
                    • Aug 2009
                    • 243
                    how is this accomplished?
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      With a DMM set to continuity beep. Look up the front and rear knock sensor pins on the DME connector using the ETM.
                      • FredK
                        • 14764
                        Look carefully on the harness wiring. The harness I have is actually labeled with 1 and 2 on the wire, right behind the boot.
                        The wire labeled 1 corresponds to cylinders 1-3. Black wire is continuous with DME Pin 70
                        The wire labeled 2 corresponds to cylinders 4-6. Black wire is continuous with DME Pin 69
                        • nrubenstein
                          • 3148
                          FWIW, the knock sensor code turned out to be a moron problem. I finally gave up and pulled the intake (quite a while ago) and discovered that I had bottomed out the bolt I'd used to install the forward knock sensor.
                          Still chasing my tail on the DME code, though.
