m50/s50 swap into 84 318i parts list
  • denisbmwm5
    • 347
    I know its been posted before all the parts you need to for a m50/s50 swap but i cant find a post or thread on that. I would like to know all the parts i will need and tips. Thanks
  • ZiMMie
    • Jun 2004
    • 968
    Good luck on ur convertion
    E30 M50 ENGINE CONV PARTS LIST
    1. E30 88' radiator, i used the e36 unit with the lower mounts raised
    2. E30 88' radiator over flow tank
    3. E30 M20 fan, poss. w/clutch
    4. E28 533i motor mounts w/ 5mm spacers or e28 m5 mounts with out spacers
    5. E34 throttle cable
    6. E21 brake booster w/ mod.shaft, to 15mm or 325IX/e32 735 without mod to the shaft
    7. E34 M5 or 25mm brake master clyninder w/ additional brake line used for the 325ix boooster
    or a e32 735i with the modded 320i booster
    8. E30 325 trans Xmember
    9. E28 m5 or two 320i trans mounts/ wich are cheaper
    10. E30 M3 driveshaft or i used the front of the e36 mated to the rear of my e30 M3 have it rebalanced
    11. E30 diff. w/ 3:25 ratio or E28 533i w/ 3:25 lsd
    12. E30 318 ecu mount
    13. E34 oil pan
    14. E34 oil pickup
    ect. ect.
    15. E36 m3 exhaust manifold
    16. M50 radiator hoses
    17. E36 M3 Motronic
    18. OBDI intake manifold
    19. OBDI throttle body boot
    20. E36 alloy mounting arms
    21. OBDI wiring harness DO NOT BUY silver label “413” motronic, it has EWS (security),
    it can only put into original chassis
    22. the engine harness and the ECU are all E36 M3.
    www.stancefactory.com
    • denisbmwm5
      • 347
      Cool thanks Zimmie! post closed.
