new to me 24v is a dud..what shal i do
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Call larger scale yards that will ship also. You may find the engine you desire for 200 freight from Ca.
    • SpecM
      • Oct 2005
      • 4531
      Originally posted by brn2ply7
      will my m50tu head fit on a s50 block and rotating assembly?
      yes, just fine
      1989 cirrisblau-metallic 325i
      • brn2ply7
        • 301
        will try and get pictures up tonight. tore it down last night to the long block
        89 325i parts car
        90 325i in progress
        ground control 400f 700r-koni adjustables-koni adjustable sways-reinforced control arms-ground control camber plates-e36 cabrio shock mounts-4.10 lsd-5 speed swap in the works
        --tryng to join the schwarz army one day at a time--sigpic
        • brn2ply7
          • 301
          1. Well leak down test showed 35% leak down on 5, though the bottom end was almost spotless. I should be picking up a s50 short block this Sunday...So theoretically with m3 cams i can make this a mock s50 correct?
          2. i am confused as to which gasket set i need to order from pelican parts if i do this..m50 gasket set OK?
          3. I am still trying to keep this on a tight budget. So with that said what all should i absolutely replace? I am going to go ahead and replace the valve springs and keepers as i will run s50 cams with the s50 bottom end. Gaskets all around are obvious as well as water pump, thermostat etc... but what else do you guys believe is necessary?
          Thanks guys, Zach
          89 325i parts car
          90 325i in progress
          • jrdeamicis
            • Nov 2008
            • 956
            it need to matches the bore of the bottom end.
            So S50 Gasket set.
            Full Gasket Set, Top and bottom.
            New 96+ Retainers
            Valve Stem Seals (Which are in the gasket set)
            Past Car : E30 S50 6 Speed 5 Lug 3.73
            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
            ___________________________________________
            BNB Designs
            Engine Swaps, Fabrication, Innovation, General Repair
            Richmond CA
            Julian 848-248-8029
            • brn2ply7
              • 301
              so if the bottom end is +4mm what do i use?
              89 325i parts car
              90 325i in progress
