ATTN: Clean Engine Bay Guys!
  • Mstngcobr761
    • Apr 2008
    • 557
    Could someone help me out and circle the brackets I DONT need in the swap so I can cut them out and clean up my engine bay a little before I paint it
  • r4esh
    • Jan 2010
    • 439
    Some stuff kind of depends... when you put the right engine in the wrong car there are is a lot of re-arranging. For instance, because of the intake you are pretty much obligated to move the power steering reservoir. I'd hop on the "24 valve engine bay pics" thread and see what other people are doing.
    (oo=[][]=oo)
    Web Design PNW
    • Mstngcobr761
      • Apr 2008
      • 557
      Yeah those are old pics, the booster and all that stuff are out right now. I skimmed through that thread and most people seemed to just leave brackets.
      • Artful Dodger
        • May 2008
        • 156
        I am in the middle of a swap my self. You can lose brackets but you will probably end up having to fab or buy brackets to hold items such as the power steering reservoir. I mounted mine to the bracket that holds the OE airbox using a spacer and the stock PS res bracket. Depending on which radiator and expansion tank you are going to use you can cut or keep the respective brackets. If you are running the 318 radiator you can eliminate the brackets for the coolant res. Good luck.
        • Mstngcobr761
          • Apr 2008
          • 557
          Planned on running Mishimotos aluminum e36 rad...cheap enough and havent heard anything bad bout them
          • Mossman
            • Apr 2006
            • 1961
            power steering res. I would mount on the drivers side engine arm like the e36 has it. Stock airbox mounts aren't needed. Coil mounting stud isn't needed.
            • 325Projectz
              • Jan 2005
              • 1956
              it depends on what you're willing to give up... washer res, abs, etc...
              maybe this will help -
              91 m3
              • Mstngcobr761
                • Apr 2008
                • 557
                Love how clean that looks, but im going to be keeping my ABS. Waser res is going bye bye to make room for my turbo
                • Fusion
                  • Nov 2009
                  • 3659
                  Wow. I just made a stain in my pants.
                  • MattM
                    • Apr 2009
                    • 931
                    it depends, early models you can shave the coolant res mounting posts off the passenger side strut. you can shave the AFM mounting contraption on the driver side fender arch, and i used the relay mounting post to mount my remote resivoir for the brake booster(ix booster), but if you are using a setup that does not require that mounting then you can shave that too.... i also shaved all the insulation off the firewall and the blower motor access hatch.
                    Full Build Thread Here
                    • e30s50dan
                      • Nov 2008
                      • 2076
                      OK thats just sick!...you got a problem sir :)
                      NASA
                      BMWCCA member
                      PCA member 25yrs
                      1991 318IS slick top
                      1997 M3 sedan
                      2001 325CI DD
                      “whoever turns the wheel the least, wins"
                      • Mstngcobr761
                        • Apr 2008
                        • 557
                        I started shaving some things...even with a spot weld drill, I had difficulty and now have some holes on my fender well...FML
                        • etxxz
                          • Feb 2006
                          • 2085
                          wow.. that looks great! my engine bay looks so more crowded even without an engine in there -.- .. look how simple it can looks!
                          No more e30s for me.
                          88 black BMW OBDII 332is dedicated track [sold]
                          88 BMW OBDII bronzit 332is [RIP 03/08]
                          91 BMW 325i [sold]
                          86 Corolla 'Ae86' HB 20v trd [sold]
                          http://youtube.com/watch?v=pTj7Hn9v5Rs
                          • Be30mer
                            • Jan 2010
                            • 1121
                            THE cleanest e30 engine bay I have ever seen.
                            You are lucky your Dad didn't pull out and leave you on the passenger side seat.
                            • jonmon6691
                              • Aug 2009
                              • 252
                              That is an amazing engine bay. How do you keep all of the vacuum lines and wires etc out of sight?
                              <-- F*** that guy
