Is this safe?
eh. I'd have safety wired it, gonna be hard to get that bitch off if you have to replace the pump. -
well, it may or may not be better than nothing. if you don't have the engine installed in the car, i would take it back apart and use a method more professionally acceptable. even lock tite would be ok. it would be pretty easy to just drill a hole through the side of the bolt head and run a piece of stainless wire through it and tie it around one of the gear holes. honestly, if i had that repair in my engine i wouldn't be able to sleep at night worrying about weather or not it would do its job.I used "JB Kwik" on my oil pump nut.
It was lathered on the threads prior to installing the nut, then applied ontop of the nut once tightened.
I've done some reading up on this stuff and the tensile strength is 2100 psi. It can withstand up to 300 degrees F*.
Im not too confident with the temperature threshold rating, some more research could've been of use before I lathered it on, but I was so in the moment you could say. :roll:
Ye, or Ne
why not just get a bolt at the dealer or mail order? can't be that expensive. why take a chance on a used bolt when your entire engine is at stake? with all of this said, i haven't heard of the pump bolt backing out unless the engine is being raced.sigpic
Gigitty Gigitty!!!!
12 135i M sport cabrio grey/blackComment
May I just list some observations?.
1,The weld stuff has a different rate of expansion than the steel wheel and the nut.
2,There will be hopefully for you numerous, but several heating and cooling cycles.
3,Oil can infuse behind the weld material via the oil pump spline drive for the wheel...like a rust penetrant.
4, the wheel will vibrate and flex in use.
5, the wheel has a certain porosity, so I hope you baked the wheel.
mComment
you'll find out one day. Certainly better than nothing. Its going to help somewhere in between nothing and a welded OPN. Safety wire or weld IMO. I welded mine after a catastrophic engine failure from the OPN backing off.No more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold]
http://youtube.com/watch?v=pTj7Hn9v5RsComment
Paypal: vdang5@gmail.com
Delta Auto Care
2875-C Towerview Road
Herndon, VA
703.435.1375
My Feedback Thread: Evil_TwinComment
^^ hundreds of e36's have successfully.. track, racers, spec guys. hell they all told me not to weld my nut but i wanted to patch my engine up (sort of like this guy here) and just talked the front of my OPN. I'd have to grind it down to remove my nut, but it certainly isn't falling off again under any circumstance.No more e30s for me.
91 BMW 325i [sold]
To replace the internal parts of an OP is significantly cheaper than replacing the pump look it up. Even if you have to GRIND the nut off you can replace the internals for under 100.Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
interesting. info to this please.No more e30s for me.
91 BMW 325i [sold]
