solid mount size?!?!
  • bloodshot-e30
    • 1494
    allright i have the stuff to make my solid mounts i just have 2 questions...
    what size height and width do they need to be
    and... do they HAVE to be offset or can the hole be straight through?
    ^Back in the game^
    BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
    FS thread:
    http://www.r3vlimited.com/board/showthread.php?t=214105
  • erik325i
    • Jan 2005
    • 3567
    I don't remember the hight of mine, but they are about 1.5" in diameter. I made the studs centered. Keep in mind the top and bottom surfaces are not parrallel.
    Erik
    • bloodshot-e30
      • 1494
      Erik
      okay thanks
      if you do end up remembering the size pleas let me know! and would you happen to remember the angle?
      ^Back in the game^
      FS thread:
      • Fusion
        • Nov 2009
        • 3659
        What material are you guys using for solid mounts?
        It would be a great help if someone had the measurements.
        • erik325i
          • Jan 2005
          • 3567
          Originally posted by bloodshot-e30
          okay thanks
          If I remember tomorrow, I'll measure them tomorrow. I made them just a hair under the height of the stock e28 m5 mounts, so if have a set of mounts already, use those as a reference.
          I never measured the angle. I just kept shaping them until they fit.
          I am using aluminum.
          Erik
          • bloodshot-e30
            • 1494
            ahh okayy
            i was gonna make mine a little taller for th header to clear? and make the left one lightly higher than the right to help with the intake manifold
            Erik
            im using either aluminum or nylon
            ^Back in the game^
            FS thread:
