Hey guys, new here. I just picked up an 87 325ie and i'm planning on doing a full restoration from the ground up. I'm trying my best to plan everything out so the whole project will hopefully go smoothly, and i'm just trying to finalize my list for the M50 swap. I'm planning on doing a full refresh on the motor and I was hoping to have anybody give me some input as far as if i'm missing anything so far. Hopefully this will also help anybody else in my same position! Anyways, thanks ahead of time and i'll be posting up pictures of the build as I go along.
M50B25 Engine with Vanos
E30/36 Radiator & Expansion Tank
M20/30 Sachs Fan Clutch
M20 Cooling Fan Blade
E28 Engine Mount
E30 325ix Brake Booster
E36 320i Transmission Mount
E36 M3 Tranmission
E36 Tranmission Filter Gasket Kit
E34 Oil Pan
E34 Oil Pan Gasket
E34 Oil Pickup
M50 OBD1 Engine Harness
M50 ECU(DME)
M50 Head Gasket Set (Victor Reinz)
S52 Camshafts (Intake/Exhaust)
M50 Supertech Valve Springs & Retainers
M50 Supertech Valves
E36 BavAuto Ignition Coil Set
E36 Bosche Starter
M50 Oil Pump
E36 Water Pump, Thermostat, Radiator Hose Kit
E36 Pink 21.5LB Bosch Fuel Injectors
M50 Fuel Pressure Regulator
M50 Power Steering Pump
E30 Power Steering Hose
E30 Power Steering Rack and Pinion
E28 Engine Mount
E36 M3 Tranmission
E34 Oil Pan
E34 Oil Pan Gasket
E34 Oil Pickup
M50 ECU(DME)
E36 Bosche Starter
M50 Oil Pump
