24v Clutch Discussion Thread
  • dinanm3atl
    • Feb 2007
    • 7305
    I am in the market to purchase a clutch for my swap. So I thought a thread to go over what motor, trans, flywheel, clutch and engine mods you were using and a review/cost/durability of the clutch you chose. I have some options on my table and looking for recommendations.
    M52 OBD1
    Intake/Exhaust/Headers
    Aasco 8lb Flywheel for M52
    ZF320 Transmission
    According to Aasco the 96-99 328i/c/s has a single part number. So I am going to have to use one of those. Waiting to hear back from friend about Southbend. Also considering a Sachs HD if available. Anyone else running something and happy? Unhappy? Plan is to rock it, wait for deal on S/C so keep that in mind.
    Post up your info and review if you please as well.
  • rThor432
    • Feb 2007
    • 3907
    I was running--
    S52 OBD1
    OBD-1 intake, 3.5 MAF, Supersprint Reps
    Fidanza 10.5 lb Flywheel for S52
    ZF320 Transmission
    Sachs OEM clutch and pressure plate
    If the car hooked up too well the clutch would slip a tiny bit. I could slip the clutch a bit and 'feather' the throttle up to about 15 mph then go WOT and have full traction with a pretty mean launch (until I cooked the diff). I wish I had invested in the Sach's HD stuff. I think that would have been a huge improvement and still been completely streetable.
    • dinanm3atl
      • Feb 2007
      • 7305
      That is how I feel. I LOVED my E36 M3 Sachs HD. Power could hold 300hp and was very stout. Many shop cars were built to track with stock motors for stock series. Worked very well. Waiting to hear how much for Southbend. I would like to be able to pound on the clutch if I want to.
      Thanks for adding to the thread. Exactly what I was looking for.
      • hugh jass
        • 2220
        I've got a UUC flywheel with the OEM E34 M5 clutch. Love it.
        ______________________
        ex-Chief Operating Officer
        Blunt Tech Industries
        West Coast and Pacific Rim
        • SamE30e
          • Sep 2007
          • 4319
          Euro 323i single mass flywheel lightened to 11.4lbs
          M20 clutch disk
          Sach's pressure plate
          It's never slipped on me, I think they sent me the wrong pressure plate because my clutch is realllllly stiff.
          On a M50B25
          1985 325e 2.8 Turbo VEMS
          • dinanm3atl
            • Feb 2007
            • 7305
            Sam. I assume on M50?
            • JJe30
              • 2044
              m50
              m20 single mass flywheel shaved down
              stock eta tranny with e30 m3 sach clutch.
              • flyboyx
                • 8371
                stock dual mass s52 flywheel, with a six puck metallic clutch and heavy duty pp. purchased off ebay. can't remember the brand, but you could search it. said to withstand about 500hp. very happy with it. hooks up real nice clark! most builders don't recommend aluminum flywheels for the street because the bolts apparently have a tendency to back out over time(even with locktite i'm told) and other reasons. if you have an unlimited budget, go whole hog. otherwise save your money on the flywheel and spend it on the clutch/pp.
                Gigitty Gigitty!!!!
                • z31maniac
                  • 17566
                  OBD-I S52
                  Getrag 260
                  13lb M20 flywheel
                  Had a local company build me a heavy duty M20 clutch capable of reliably holding 300lb ft of tq.
                  Lightened flywheel/resurface, disc/pp/throwout bearing/alignment tool = $275
                  Unless you are planning on turbo/supercharger or something, I see no reason to drop the money on the M5 clutch setup or anything else that extreme.
                  www.gutenparts.com
                  • rThor432
                    • Feb 2007
                    • 3907
                    That's what I thought, but my OEM setup never seemed 100% when I really loaded it up.
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      What tires were you running to get your clutch to slip?
                      '89 Alpine S52 with goodies
                      • dinanm3atl
                        • Feb 2007
                        • 7305
                        Sachs on my E36 M3 with up to 255s would always smoke over tires even if side stepping in first. On an e30 it shouldn't slip.
                        I think I am going with Southbend.
                        • matt
                          • 3732
                          Keep in mind, the e36 M3 clutch setup is not the same as the 328 clutch setup, even though both are 240mm.
                          I ran a stock M3 clutch in mine. It was bangin. I will probably go with an M3 aluminum flywheel and a Southbend clutch when I go turbo.
                          PS I have driven a lot of high-performance clutches (clutchnet, kennedy, FX700, etc) and NONE of them can hold a candle to Southbend. It's smoother and easier to drive than anything else at the same torque capacity.
                          • Dominic49
                            • Feb 2007
                            • 1373
                            we ran a lightened m20 flywheel and stock used clutch on the s52 drift bitch and it never slipped.....
                            • dinanm3atl
                              • Feb 2007
                              • 7305
                              Yah. I drove Jordan's car. Feels real nice. Probably going to do a Stage 2 for the eventually supercharger so I never have to worry. Plus the warranty and customer service is good.
                              I got a "M52 Aasco" so I have to run the M52 style clutch.
