I know this has been covered 8 bajillion times, but i'd like to hear from the pro's what i'm missing before i start my swap.
Engine: S50B30 from a 94 M3
Transmission: Stock ZF from the M3
parts acquired.
AKG motor/tranny mounts
AKG wire harness adapter
E34 oil pan
E30 M3 drive-shaft
AKG DTM shift lever
UUC 9lb flywheel E34 M5 clutch
UUS DSSR made for S50 swaps... hope it fits!
VAC full 50mm stainless steel exhaust
VAC 50mm E30 M3 exhaust flange
VAC S50 exhaust flange
I'm going to make a short connector between the exhaust manifolds and where the E30 M3 manifold is. Hopefully this works....
issues i haven't sorted out:
Brake Booster - I have a hydro setup from a 750iL, but it's only the part that mounts to the firewall, I believe I have to pull the 750 PS pump, and i'm not sure if that will mate to the S50 block. any other ideas?
radiator - I'm going to use the stock one from my 89 325. I couldn't decide on M42 radiator, or S54... what say you?
Coolant hoses - I got nothing on this part...
Alternator - jackass that sold me the motor sold the alternator before i picked everything up, will a regular M50 alternator work?
P/S pump - same as alternator, can i use the regular M50 stuff, my M20 stuff, or possibly the 750iL PS pump w/ the hydro boost.
EWS - i have that damn silver label 075 DME. I have the key and the EWS box, but i'd rather go without it all. Is there any good write-ups on getting EWS to work in the E30? I have no harness for the components, just the boxes and key cylinder. Or just find another DME from england or something?
My plan is to drop the M20 down by unbolting the front subframe. Bolting the S50 to the subframe then lowering the car onto it.
SOOOO, what haven't I thought through?
Thanks guys,
parts acquired.
E34 oil pan
E30 M3 drive-shaft
AKG DTM shift lever
Thanks guys,
