Abs
  • nrubenstein
    • 3148
    Abs
    OK, so before the swap, ABS either worked, or at least had not turned on the ABS light.
    I have one of the cars that used the late brain with the fusible link, rather than the fused relay. The link is intact, and I've tried swapping brains to no avail.
    Any suggestions on what I should look for next?
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
  • FredK
    • 14761
    Do you have an airbag car?
    • nrubenstein
      • 3148
      No, but it's 2/89 production, so it's fairly close to the airbag car dates.
      • surebimmer
        • Jan 2004
        • 978
        Most of the time the ABS doesn't work, the relay has gone bad.
        • nrubenstein
          • 3148
          As I noted in the original post, the car does not have the fused relay.
          • nrubenstein
            • 3148
            Aha. It looks like this is the issue:
            Hopefully, I'll get that solved this weekend.
