Smallest Booster
  • BUDNUNTA
    • Apr 2005
    • 996
    Smallest Booster
    Which brake booster is the smallest?
    E21, 2002, geo metro, golf?
    Hunter
    We're out there in here.
  • Massive Lee
    • Sep 2006
    • 6785
    Geo metro is smallest. And it offers very minimal assist. and you must use a Geo Metro MC if I remember correctly.
    e21/2002 are similar except for the length of the rod (e21 is easier to mod). It offers enough assist so that you don't grow gorilla legs.
    No experience with the VW stuff
    massivebrakes.com
    • BUDNUNTA
      • Apr 2005
      • 996
      Ive got your sport kit Lee
      Any other small boosters I should know about?
      • Massive Lee
        • Sep 2006
        • 6785
        You can use small booster (or even no booster at all) if you use pads with a high coefficient of friction. But it usually only applies to race set-up as such high friction pads are not always street friendly, meaning they can grind rotors over a long period of time if used cold continuously.
        If you don't mind replacing your discs every year, then may I suggest Wilwood's H compound. It is a high friction, enduro pad that lasts a very long time, and has 85-90% of its total friction even when dead cold. PAd is not cheap, but well worth the expense.
        Are you fitting an M50 motor? If so, I suggest the e21/2002 booster moved away (from the engine) by perhaps 3/8" to 1/2". You won't have to grind the fins on the intake manifold. Stick to 21 or 23mm MC
        BTW I am about to start a thread about using a same size bore MC vs the e30 differential bore MC.
        massivebrakes.com
        • bejbis
          • Dec 2008
          • 596
          If you played softball in high school, you wont have a problem.
          You missed comments on the ix/e32, also the 944 booster. I did the e32 booster and master and love how the brakes feel. However i think its the largest booster setup you can go with and still do a swap. I think the 944 booster is about the same size as the e21 booster.
          -Dan
          • BUDNUNTA
            • Apr 2005
            • 996
            Im actually not going 24v
            Im making room for a new intake manifold on my m42
            From further searching it seems the golf booster is smallest at 9" diameter, then e21 at 9.25" and the 944 being 9.5"
            Supposibly the geo one is 8" but idk about that one
            Honestly probably nothing wrong with it, but really using parts from a geo?
            Is it pretty much bolt on like the rest ?
            • Massive Lee
              • Sep 2006
              • 6785
              The Geo booster has a different bolt pattern. Slightly smaller.
              Lee
              massivebrakes.com
              • JeffRR
                • 277
                I'm using the 924 booster and its a little smaller dia than the 944 version.
                • Eric
                  • 5142
                  what year/model golf?
                  • rThor432
                    • Feb 2007
                    • 3907
                    I know some of the guys over the pond have used the MK1 Golf/Rabbit booster. Not sure about the specific year range.. I bet the info is all over some of the forums for your area though.
                    • dave.a.cote
                      • Jul 2009
                      • 246
                      I would like to know more about the golf booster as well - I heard that mk2 boosters work but not sure though.
                      1988 325 auto-x car
                      1989 325ix winter car
                      1991 525i summer car
                      • rThor432
                        • Feb 2007
                        • 3907
                        ^^They probably will work. The big benefit of the MK1 booster is that it will fit with the individual throttle plenum on the S50, as I understand it. I'd like to get my hands on one..
                        • BUDNUNTA
                          • Apr 2005
                          • 996
                          which booster do you guys think this is?
                          • Adrian_Visser
                            • Jun 2006
                            • 2823
                            I don't have a clue but those velocity stacks are fawking hawt!
                            '89 Alpine S52 with goodies
                            • E30SPDFRK
                              • 5716
                              What is stock e30 booster diameter for comparison?
                              Byron
                              Leichtbau
