CEL fucked up idle and dies???
  • 5KWattson
    • Apr 2009
    • 809
    So I pressure washed the underside of my car today, it ran fine, got home let it sit for about 3 hours. And BAM it started running like ass throwing Me a bright fuckin CEL, any idea's? I haven't tried pulling codes yet. I heard you can do the stomp test is this true in the e30?
    "God created turbo lag to give V8's a chance" Taylor D.
  • flyboyx
    • 8371
    since you are talking about the stomp test, i assume you don't have a peak scanner/reset tool. there is a way to reset your dme without it that may be all it takes to make your car run right.
    Gigitty Gigitty!!!!
    • 5KWattson
      • Apr 2009
      • 809
      Do you know how than? I'm kinda drawing a blank man
      • 5KWattson
        • Apr 2009
        • 809
        SOB i did the stomp test came back 1215 Air/Mass volume code guess its time for a new one...unless i spot some vacuum leaks at work tomorrow...and what do you know the MAF i bought when i got the m50 is now out of warranty FML
        • xwill112x
          • Jan 2009
          • 4236
          probly just knocked a vaccum hose loose somewhere.
          • r4esh
            • Jan 2010
            • 439
            Also. Could water have gotten in to a sensor or spark plugs somewhere? I washed my engine bay once and water got down in where the spark plugs are... some compressed air got it out and it was fine. It ran like I only had a few cylinders until then.
            (oo=[][]=oo)
            Web Design PNW
            • 5KWattson
              • Apr 2009
              • 809
              possibly but its running very normal today and i havent done anything to it
              yea i dont think so its not the same missfire like when i did that previously it was all over and not consistent at all, but its back to normal now so prob just water in a connection...which i should look at now for corrosion
              • graphikg
                • Jan 2008
                • 1614
                Mine is throwing a 1218 code. My vaccum also leaking somewhere. I was trying to figure it out with jrdeamicis ans we think it is a firing issue, vaccum or fuel issue. Sounds like vaccum though, and it sounds like the rpms drop when the accelerator is pushed. Any ideas for me?
