S52 + g240 = ??
  • e30s50dan
    • Nov 2008
    • 2076
    S52 + g240 = ??
    Ok, I know,I know....but I have a lead on a good S52 for little money,and was wondering how a G240 might hold up to the S52 power/torque. I searched and couldnt find anyone with this combo,all though there is one guy with a D mod racer putting out 300hp and is running a g240,and said so far so good.
    I want to remove the m50nv and install the S52 obd1 and be done with it.
    thoughts,bitches,complaints??
    tia
    Dan
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
  • Dominic49
    • Feb 2007
    • 1373
    we ran a 240 on the s52 drift car and hundreds of clutch kicks later it was still great...
    • e30s50dan
      • Nov 2008
      • 2076
      What clutch/flywheel combo were you using
      NASA
      BMWCCA member
      PCA member 25yrs
      1997 M3 sedan
      2001 325CI DD
      • 619E30
        • 1753
        it should hold up fine with a good clutch and lightened flywheel
        Originally posted by audiquattrot
        bimmers b4 b*tches....remember that.
        1990 Alpinweiss 325i - secret 500whp build
        2000 Audi S4 B5 Laser Red
        1990 Nissan 240sx - Drift Missile
        2006 CBR600RR
        • Dominic49
          • Feb 2007
          • 1373
          we used the m20 flywheel and stock m20 clutch with a euro 323i TOB
          • e30s50dan
            • Nov 2008
            • 2076
            I have a lightened m20 flwheel and sach sport clutch now
            NASA
            BMWCCA member
            PCA member 25yrs
            1997 M3 sedan
            2001 325CI DD
            • xwill112x
              • Jan 2009
              • 4237
              itll trash it after a while, dont expect to be snapping gears like your a drag racer everywhere, a local guy trashed a g240 with a nvm50 in a couple of hours, so dont be a idiot and youll be fine
              • e30s50dan
                • Nov 2008
                • 2076
                ^ yea iam not a drag racer, although will want to track it I must admit the tranny is holding up nicely
                well he'll now I'm exited about the s52 I have everthing fo the obd1 swap and clutch and a nice low mileage 3.73 LSD that was in my automatic e30. Should make for an interesting combination
                NASA
                BMWCCA member
                PCA member 25yrs
                1997 M3 sedan
                2001 325CI DD
                • lifeiskaos
                  • 1709
                  Matt (mr 325) is using one with his s52 IIRC
                  • red911turbo
                    • Oct 2006
                    • 222
                    Why was the euro 323i throw out used?
                    E30 325i 24v, E36 M3/4/5, MK2 GLI 16v, NA8 Miata
                    Prestige Auto Repair
                    Mercedes-Benz|BMW|MINI
                    prestigegermanrepair.com
                    • ethrty
                      • Nov 2009
                      • 342
                      also keen to know
                      • rThor432
                        • Feb 2007
                        • 3907
                        It has a different length from a 260 throw-out bearing that works with the 240 box. I had them side by side and iirc the 323i T/O is slightly longer.. even though I would think it would be shorter to work with the smaller/shorter 240 box..
                        I'd like to know if this box would hold up as well. I like that you can run the 240 and have a Getrag (much better feel than the ZF, in my opinion) and the trans isn't rotated. I'd like to try that with my next M/S50/2 conversion. I always liked that box in my 318is.
                        • SamE30e
                          • Sep 2007
                          • 4319
                          I've beat the absolute shit out of mine and nothing yet. It will be fine for track, it's just the drivetrain shock of launches that will kill you if anything.
                          1985 325e 2.8 Turbo VEMS
                          • Hartge_H27
                            • Jun 2006
                            • 1699
                            I have one on my supercharged S52 and its held up fine so far.
                            • ethrty
                              • Nov 2009
                              • 342
                              oh that will be the same as my one then. mine is a euro 320i one. The M20B20 came with a g240 bolted to it from the factory so must be the same thing
