A/C Idle Bump
  • nrubenstein
    • 3148
    A/C Idle Bump
    Is the A/C idle bump wire run to the X20 connector? While I'm fixing my adapter for ABS, it seems like it would be a lot easier to run a wire out there than it would be to take apart the wiring sheath at the DME connector.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
  • Dominic49
    • Feb 2007
    • 1373
    yes the wire is on the x20 of the e36 harness and under the dash of the e30 either run a wire or do it at the ecu connector its not hard either way.
    • nrubenstein
      • 3148
      Yes, pin 6 on the x20.
      Why isn't there an adapter made with this already? Not that it was that hard to add.
