I made me this intake elbow to alleviate a few problems i had with the stock elbow. Most of the problems I had with the stock elbow was clearance with the brake setup, as well as having the air filter run into my oil cooler lines. I also had problems with finding a non cracked boot and having something that could be boosted.
This is made out of 6061 3'' aluminum pipe, and was radius cut and welded together to achieve the bend necessary to get such a tight bend off of the throttle body, mandrels cant bend that tight. The elbow is angled down and leveled out so the connector of the HFM sits in the hole of the bracket where the air filter box used to attach. Its a real clean setup.
If there is any interest I will throw a couple of these together. Price would probably be around 120-130 shipped per. Not including the couplers or the clamps.
-Dan
-Dan
 Gauging interest for Aluminum intake elbow for m50 swap.
