Maximum bore size for alloy M52 block?
  • alexbaby88
    • 219
    Whats the max I can bore out my M52 alloy block (stock 84mm)?
    Are there any significant differences between the M52 and US S52 blocks?
  • lifeiskaos
    • 1709
    • alexbaby88
      • 219
      I already have a stroked 3.0L on an M52 block and was looking into the feasibility of bringing up the capacity to 3.2L via a bigger bore.
      Any significant differences between M52 and S52 blocks?
      • lennon
        • Jun 2008
        • 1416
        You can't bore those alloy blocks much at all without going right through the sleeve and into the water jacket. You would need some not-worth-it custom work to get an 86/87mm bore in an alloy m52.
        I assume you mean differences between iron m52 and s52 blocks? If so, then there are no significant differences.
        What's your setup now? I'm curious.
        • alexbaby88
          • 219
          OK thanks for that info.
          I originally had a stock M50 B25 but have now stroked it to a 3.0L on an alloy block M52 using M54 rotating parts (same crank as S52) with 84x89.6 bore/stroke using OBD 1 413 ECU with TMS S50 chip.
          • e30polak
            • 6136
            Have you dyno'd it? I'm interested to see how it performs with the lower compression ratio NA.
            INSTAGRAM: @UNDR8D_EMPIRE
            • alexbaby88
              • 219
              No I haven't dyno'd it yet. The M54 has the same 10.5 CR (IIRC) as the S50. As I also have the S50 cams I reckon it should make similar power to the S50 at about 240 bhp at the crank. I'd be pretty disappointed if it didn't come close LOL!
