Any good resources for fining out wiring locations.
  • Unearth078
    • May 2008
    • 2623
    just curious if anyone has made a chart as far as what connector goes where by color code.
    If not ill just peel back the boots, or repost on the forums like everyone else. :p
    Originally posted by Lof8
    4 doors allow you to transport more whores.
    therefore, their value is much greater.
    Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
  • samiam3356
    • Jul 2009
    • 1901
    I did a continuity(sp?) test on each connector to make sure they are right. Just didn't trust the colors for some reason. Only one I couldn't nail down doing this was the TPS and I went off the color on that one.
    Not that hard though, I think a easy read format would be by how many wires the connectors have.
    Ex:
    3 Wire Connectors and then a column for the wire color, hard to do on here
    1-3 Knock Sensor
    4-6 Knock Sensor
    Cam Sensor
    Crank Sensor
    TPS
    Oil Level Sensor
    ICV
    2 Wire Sensors
    DME Temp Sensor
    Cluster Temp Sensor (Sensor actually has 1 connector)
    1 Wire Sensor
    Oil pressure sensor
    Not everything, but I think it would be easier for people to read and understand.
    Originally posted by Roysneon
    $5 shipped?
    Originally posted by MarkD
    You are a strange dude, I'n not answering any more posts from you.
    • loonibab325i
      • Dec 2005
      • 770
      s52 0-150mph & more http://www.youtube.com/loonibab325i
      • Unearth078
        • May 2008
        • 2623
        You guys rule!
