s50 swap help
  • blackhawkimpact
    • 2415
    s50 swap help
    I have an s50 but I'm missing some brackets and some hoses. Anyone have a pic of the engine's sides? Im looking at realoem.com but still a bit confused.
    I check this on realoem and it tells me its from the s52 and it doesnt come on the s50.
    This is the part that suppose to go instead of the one above, according to realoem.
    Any help i would appreciate it.
  • r4esh
    • Jan 2010
    • 439
    They call it the "spider hose" if you search that you should find more about it. Basically the s50 one (rubber) and the s52(the hard metal one) do the same thing. So from what I gathered you are m/s50 ??? In which case you would use the rubber one because there is a fitting for the rubber hose to be clamped onto on the front end of the engine block. (see it?). HOWEVER some people prefer the metal line.. because... well... its metal, lasts longer, etc, etc. - If you go with that one, you'll have to chop the end of it a little and use a hose clamped on both ends to get it to connect to the block.
    Make sense?
    here is a rough pic i found... (not my car)
    (oo=[][]=oo)
    Web Design PNW
    • blackhawkimpact
      • 2415
      I got it. that pic help a lot thanks.
      • Fusion
        • Nov 2009
        • 3659
        And don't forget:
        Heater Core Coolant Hoses
        The "spider" hose connects to the top heater core pipe out of the firewall in the engine bay.
        The coolant hose from the back of the head connects to the bottom heater core pipe out of the firewall in the engine bay.
        This step is important, otherwise the heat will not function very well i.e. it gets cold anytime the car is at higher RPMs.
        • blackhawkimpact
          • 2415
          Thanks Fusion.
          • blackhawkimpact
            • 2415
            Ok, now I'm a bit comfused on how to connect the "spider hose" to the throttle body. I tried looking for some pics but no look.
            • sharky
              • Jan 2005
              • 2672
              Thats a S52 buddy, use the metal pipe, it fits fine. You will have to fad up some heater core hoses from the pipe to the bulkhead but it is easy.
              • blackhawkimpact
                • 2415
                What's an s52?
                • Fusion
                  • Nov 2009
                  • 3659
                  S50 http://myndasafn.bmwkraftur.is/d/8583-2/IMG_3290.jpg
                  S52 (newer generation M3) http://img132.imageshack.us/img132/3843/motornb2jn3.jpg
                  Notice the difference in intake manifolds.
                  • JRKOUPE
                    • Dec 2004
                    • 3159
                    that s50 pic;d appears to be a euro model......
                    • VEGETA7
                      • 64
                      even the knock sensors are obd2
                      • blackhawkimpact
                        • 2415
                        I checked the vin that's on the head and it said it's an s50 from a 95 m3?
                        • Fusion
                          • Nov 2009
                          • 3659
                          I stand corrected. I'll shut up now.
                          • blackhawkimpact
                            • 2415
                            Is there a way that the previous owner could of change the head to an s50? So far according to realoem some parts that are on the motor are only from the s52 and doesn't come on the s50?
                            • blackhawkimpact
                              • 2415
                              Oh nvm I know what you meant fusion... Yeah that s50 your showing is an euro s50
